Riedon resistors...anyone ever use?
0 Members and 1 Guest are viewing this topic. Read 3012 times.
BillB
« on: 23 Apr 2009, 12:58 am »
Might be the new high price leader  :nono: Not sure how I ran into these but they are high precision resistors, .01% dealies.
http://www.riedon.com/us/index.php?page=shop.browse&category_id=7&option=com_virtuemart&Itemid=47
Digi-key had a few of them...they are a minimum of $18 a piece.  :nono:
Just curious if anyone has ever seen them used in audio.
cryoparts
Re: Riedon resistors...anyone ever use?
« Reply #1 on: 23 Apr 2009, 01:09 am »
I've played around with them a bit.  They are really well made, perhaps a good alternative for those who want to eke out every last ounce of performance from an already exceptionally well designed piece of gear.
Lee
BillB
« Reply #2 on: 23 Apr 2009, 01:13 am »
Are we talking naked vishay levels of precision or better (worse?).
I cannot imagine ever owning something that would need these but they do seem like a good idea for signal path resistors in tube gear (if you are looking for non-coloration from resistors).
Do they sound sterile? It almost seems anything with a precision >1% is almost too clean and precise.
cryoparts
« Reply #3 on: 23 Apr 2009, 06:04 am »
Very precise tolerances, incredibly well made.  I haven't directly compared them to the nude Vishay's, so not sure how different, or similar, they are.
I have quite a few Riedon's somewhere at the shop, not sure what values, I'll have to find them and check them out again.
Lee
andrewbee
« Reply #4 on: 24 Apr 2009, 01:45 pm »
At .01% they would be overkill for even a concertina splitter for which I spec 0.1%. I did not look at the prices but I will take a wild guess that I can buy probably 100 "ordinary" metal film resistors and get lots of matched sets for less $.
cryoparts
« Reply #5 on: 30 Apr 2009, 11:49 pm »
OK, I've tried them in two similar pieces of gear, a customer's 2008 Valab/Teradak NOS DAC and my 2009 Teradak NOS DAC and have been impressed enough to post about them here.
I used 350ohm .6w in the I/V section, replacing the stock Dale's that were in there.
If anyone is as crazy as I am and is willing to spend $18.50/each plus shipping for these things, I don't think you'll be disappointed.
Peace,
Lee
