For Sale: DVDO iScan VP20 High Definition video processor: Like new
0 Members and 1 Guest are viewing this topic. Read 1463 times.
AV Guys
  • AV Guys (my hubby and me), totally into AV :)
The DVDO® iScan™ VP20 is a high-definition video processor and A/V hub that converts standard or high definition from your DVD Player, VCR, PVR, HD set-top box, game console or PC to any of the predefined output resolutions between 480p and 1080p, including popular HDTV resolutions such as 720p or 1080i.
Enjoy this great video processor/switcher for a fraction of MSRP!
This amazing unit will take on any built-in processing chip found in your TV or AV receiver, with bonus additional added features such as:
-       Multitude of video and audio inputs and outpus, simultaneously selected.
-       Custom audio delay settings to help you with HD processing and broadcasters notorious lip-sync issues (of which even national broadcasters are not exempt from…).
-       Built in test pattern generator (35 patterns, see movie clip below) for calibration without the need for an external unit.
-       10 Custom user presets allow you to store your profiles (display, frame rate, image shift settings) for easy recall.
-       Powerful zooming/panning and cropping settings, per preset.
-       RS-232 control for seamless integration with Crestron/AMX/Universal remote/Pronto systems.
-       Easy to use on-screen menu system (no need to decipher those tiny LCD “codes”)
(See full description below).
Condition:
The unit is in like-new condition, with the smallest nick on the top left side (see pics @ http://picasaweb.google.com/our.ebay.photos/DVDOIscanVP20#). It comes in its original box, complete with manual, quick guide, CD-Rom, remote, VGA cable and A FREE 3’ HDMI CABLE to make this add-on easy and quick so you can enjoy amazing picture quality in minutes!.
I made a movie clip @ http://www.youtube.com/watch?v=tDsz0iz72yI of the unit in action, showing its easy to use menu system and features.
Shipping:
The unit will be shipped double boxed for extra protection.
Please contact me with any questions - Thank you for looking!  We accept paypal.
Asking price: $900. Offers welcomed!
(Full product description)
Overview:
Features:
    * Precision Video Scaling IIT: 10-bit Scaling with Enhanced Sharpness Control
    * RightRate™: High-Performance Framerate Conversion
    * AutoCUE-C™: Automatic Chroma Upsampling Error detection & correction
    * Precision AV LipSync™: Intelligent digital audio delay technology to match Audio & Video timing
    * AutoVFR™: Intelligent Component Video Inputs with Automatic Video Format Routing
    * NTSC (3:2 and 2:2 pulldown; video) and PAL/SECAM (2:2 pulldown; video) sources
    * Display Profiles: User-defined memories (10) for multiple display, framerate, and image shift configurations
    * RS-232 control: for integration with automation and control systems from Crestron, AMX, Elan, Universal Remote and others.
    * Flexible Input and Output Aspect Ratio Controls
    * Full-frame Timebase Correction
    * High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
    * High-quality super-adaptive comb filter with 2D Y/C separation
    * Software Upgradeable (via RS-232)
·         Predefined Output Resolutions for Plasma, DLP, LCD, LCOS and CRT-based displays
o    Digital Television Standards: 480p (720x480), 576p (720x576), 720p (1280x720), 1080i (1920x1080), 1080p (1920x1080)
o    PC Resolutions: VGA (640x480), SVGA (800x600), XGA (1024x768)
o    Other Presets: 852x480, 1024x576, 1024x1024 (ALIS), 1280x768, 1366x768, 1360x768
Inputs/Outputs and Routing:
The VP20 also serves as your complete A/V hub, providing simultaneous audio/video switching with video up/ down/ cross-conversion with one digital HDMI connection to your display or projector. You can conveniently connect and select any audio/video input combination from the following:
Nine Video Inputs:
    * 2 Composite (NTSC/PAL/SECAM)
    * 2 S-Video (NTSC/PAL/SECAM)
    * 2 Component (YPbPr or RGB/S) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60
    * 3 HDMI (RGB or YCbCr) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60, VGA-SXGA@60Hz
Eight Audio Inputs:
Flexible Digital and Analog Audio switching and routing - 3 HDMI audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI audio/video output and 2 active digital audio outputs.
    * 3 HDMI
    * 2 Assignable Coaxial Digital
    * 2 Assignable Optical Digital
    * 1 Assignable Analog Pair (L/R)
One HDMI Output:
    * Audio/Video Output
    * Configurable for YPbPr or RGB
    * Also carries digital audio
Two Digital Audio Outputs (Simultaneously Active):
    * One Coaxial Digital
    * One Optical Digital
Technical specifications:
Input Aspect Ratio Controls
    * Presets: 4:3 full frame, 4:3 letterbox, Panorama (non-linear stretch), 16:9 full frame or user defined aspect ratio (10)
    * Flexible Horizontal and Vertical Zooming (up to 2x) & Panning Controls
    * Overscan Adjustment per input
    * Presets: 4:3 or 16:9
Picture Controls
    * Fully programmable controls with non-volatile memories
    * Each input has an individual memory for each processed format
    * Brightness, Contrast, Saturation, Hue, Sharpness, and Fine Y/C Delay (sub-pixel)
Operation:
    * Intuitive On Screen Display
    * Easy to read 2 line, 20 character Backlit Front Panel Display
    * Front Panel Controls
    * IR Remote Control (discrete codes available)
    * Automation via RS232 port
Output Controls
    * Output Resolution
    * Sync Type
    * Colorspace (RGB or YPbPr/YCbCr)
    * Frame Rate (NTSC ? PAL Conversion)
    * Gamma
35 Built-in test patterns
Software Upgradeable via Serial Port
Power:
    * Universal AC mains input: 100 - 240 VAC @ 50 - 60 Hz
    * Consumption < 45W
    * Sleep mode - automatic 30 second timeout indicated by power LED turning off
Physical Dimensions:
    * 10.4"x17"x2.2" (26.3cmx43.4cmx5.5cm) with feet
    * 10.4"x17"x1.8" (26.3cmx43.4cmx4.6cm) without feet
    * Standard 19" 1U 1.75" Rackmount available
Weight:
    * Shipping - 10.5 lb (4.8 kg)
    * Unit without Power Supply - 6.4 lb (2.9 kg)
