My OB
0 Members and 1 Guest are viewing this topic. Read 7149 times.
xecluded
My OB
« on: 21 Apr 2009, 09:33 pm »
Here are my new OB.
Top part is single 5" fullrange running by iself and augmented with goldwood.
The rest is 10" Eminence Lil Buddy, B&C DE10 / ME10 drivers/horns and 18" goldwood.  Crossover is 2nd order per econowave thread at audiokarma:
http://audiokarma.org/forums/showthread.php?p=1856214#post1856214
JoshK
Re: My OB
« Reply #1 on: 21 Apr 2009, 10:14 pm »
Is this so you can have two different systems in one speaker?
xecluded
Re: My OB
« Reply #2 on: 21 Apr 2009, 11:02 pm »
That's the reason. :green:
Saurav
Re: My OB
« Reply #3 on: 22 Apr 2009, 03:54 am »
My DE10/ME10 arrived yesterday, I hope to take some measurements this weekend. How do you like that combination? I was running a BMS CD on the 1086 horn for the last year, and decided to try this tweeter/horn combination in the hopes of being able to achieve better crossover integration. The >3" acoustic offset difference between midrange and tweeter was more than I could handle.
xecluded
Re: My OB
« Reply #4 on: 22 Apr 2009, 12:03 pm »
They work well for me.  Please let me know how does your project turn out.
ebag4
Re: My OB
« Reply #5 on: 22 Apr 2009, 04:17 pm »
X,
Very cool solution.  I sometimes want to get back to single driver but room for multiple sets of speakers is always an issue.  I really like what you have come up with, great job!
Best,
Ed
xecluded
Re: My OB
« Reply #6 on: 23 Apr 2009, 03:08 am »
Thanks Ed.   I've always like single driver and with the goldwood - they are now even more enjoyable.  I could not do this without the articles from MJK - Many thanks Martin !!!!
freddyi
Re: My OB
« Reply #7 on: 23 Apr 2009, 08:23 pm »
hi xecluded - where does your EM Buddy rollin in and out and how do you like it?
xecluded
Re: My OB
« Reply #8 on: 23 Apr 2009, 08:52 pm »
freddyi, i dont have test equipment to test.  first, i crossed them at 1200hz 2nd order per econowave guide instruction at audiokarma;  though lately i've been running them with just a 1.3mh and preferred it this way.  they are really nice  - better than anything i've ever had.
Arlo
Re: My OB
« Reply #9 on: 24 Apr 2009, 12:12 am »
What is the magnet weight on that 18" unit?
xecluded
Re: My OB
« Reply #10 on: 24 Apr 2009, 02:03 am »
"What is the magnet weight on that 18" unit?"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-386
freddyi
Re: My OB
« Reply #11 on: 24 Apr 2009, 04:16 am »
CooL! - your woodwork looks great - there should be plenty of bass - more woofer magnet would not be as good
- H-baffle in extermely cramped space with GW1858 - almost level from 100 to 30Hz - other trace is an inverted tapped horn in a corner
holdent
Re: My OB
« Reply #12 on: 30 Apr 2009, 12:17 am »
freddyi:
Very interesting measured response of GW-1858 in the H-frame!  I assume this is without a passive crossover such as used by Martin King here http://www.quarter-wave.com/Project08/Jordan.pdf.  If so, MJK's modeled response for the system is impressively similar to what you measured.
Angaria
Re: My OB
« Reply #13 on: 10 May 2009, 10:55 am »
any particular thoughts on the sound of Eminence 10"?  Was concerned about the audibility of their resonance ~2kHz.
xecluded
Re: My OB
« Reply #14 on: 10 May 2009, 12:31 pm »
They sound excellent after break in (took a long time.)  I went back to 2nd order on the woofer at 1200hz per econowave schematics. Did not hear any resonance.
ga foo 88
Re: My OB
« Reply #15 on: 22 May 2009, 04:22 am »
the de10/me10 combo is in the tidbits section on zaphaudio... if that is common knowledge i'm sorry :green:
http://www.zaphaudio.com/tidbits/
Telstar
Re: My OB
« Reply #16 on: 22 May 2009, 06:44 pm »
How long?
xecluded
Re: My OB
« Reply #17 on: 24 May 2009, 10:34 am »
How long?
2+ months.
