Romex?
0 Members and 1 Guest are viewing this topic. Read 1664 times.
Nick77
Romex?
« on: 20 Apr 2009, 12:24 am »
Hi we will be building our home this summer and I will be able to install dedicated lines to my av room.
Question that I had was upgrading the wire from the panel to the av room only. My search only came up with a Cardas in wall product but at $12 a foot that could be silly expensive.
Are their any good high quality romex options just for runs to av room? Thanks
gitarretyp
Re: Romex?
« Reply #1 on: 20 Apr 2009, 12:41 am »
I'd say go with regular 10 or 12 AWG Romex. You can get cryoed romex from VH Audio, if you prefer.
satfrat
Re: Romex?
« Reply #2 on: 20 Apr 2009, 01:01 am »
VH Audio sells cryoed Romex at $2.99 a ft. and can be found here under AC Power.
Robin
Nick77
Re: Romex?
« Reply #3 on: 20 Apr 2009, 01:42 am »
Robin
Can anyone comment on results with cryo Romex, worth the extra money? Thanks
markC
Re: Romex?
« Reply #4 on: 20 Apr 2009, 02:22 am »
Although I've never had the pleasure of auditioning cryoed romex, I couldn't imagine spending 3X the price over non-treated for it to wire my room. Unless I had money to burn on the project and a very high dollar setup, I'd go with a dedicated run with standard 12 ga NMD90. (Romex)
mjosef
Re: Romex?
« Reply #5 on: 20 Apr 2009, 03:13 am »
If you choose to go with regular 'romex', and the run is over 50ft. make sure and use 10Ga.
Its a little harder to terminate, but the extra guage makes a difference.
