Power conditioner for NuForce P8 pre or Ref8.5v2 monosamps?
0 Members and 1 Guest are viewing this topic. Read 1649 times.
jwo
As I understand the NuForce monoamps gets an advantage with o good powerconditioner or filter.
My question is: Does the nuForce P8 pre advantage just as much from a good powerfilter or conditioner?
If I have just one power filter with 2 outlets, should I connect my 2 nuforce ref8.5v2 monoamps in it or should I connect my nuForce p8 and my benchmark Dac!?
Or should I connect both the P8 + Dac + monos ???
The power conditioner i'm gonna use is the Ps Audio Ultimate outlet highcurrent rev4.
Please help.
/ Your friend Jon, Sweden
jwo
anyone?  :roll:
rustydoglim
    • www.nuprimeaudio.com
Sorry, I can only recommend Black Noise 2500. For that, you can connect the amps and preamp to it for the best AC Noise filtering and surge protection.
montag451
what i experienced, with good result, is the electrical separation between the 8.5 V2s and the rest of the equipment.
it just works fine with a black noise's miniblack. you can notice, as a major effect, the disappearing of an "haze effect", probably due to the electrical pollution injected by the power amps. every filter with a two way action (in and out filtering) should guarantee the same appreciable effect.
