Digital Cable for BDA-1
0 Members and 1 Guest are viewing this topic. Read 5680 times.
audio 1
« on: 17 Apr 2009, 05:37 pm »
I just received my BDA-1 and I will be using it with my Squeezebox Duet.  I would like to know what coaxial digital cable others are using for this application or any recommendations based on similar experiences.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Digital Cable for BDA-1
« Reply #1 on: 17 Apr 2009, 05:47 pm »
http://bryston.com/bnc.html
james
werd
« Reply #2 on: 17 Apr 2009, 06:39 pm »
Hey Audio 1
How is the 14 sst/2 working out for you? I use the Atlas opus http://www.atlascables.com/index.php?id=231 in 1.5 mtr.
Steve Nugent (Empirical Audio), recommends the 1.5 mtr for length on the 75 ohm digital coax. There are tech reasons for it.
This digital coax is really nice and i have had a few diff types, like ultra link, kimber illum, harmonic tech and a few others.
Best one i've heard so far.
I am particularly interested in how what you think of the squeeze box also with the bda1.
audio 1
« Reply #3 on: 17 Apr 2009, 07:03 pm »
Hi Werd,
The 14bsst-2 is working out very well.  It is simply an amazing amplifier that has an almost non-existent noise floor and superb sound quality.  The soundstage it creates is extraordinary and its ability to control the bass frequencies and present amazingly natural grain free treble is a real delight.  My speakers sound better than they ever have with the combination of electronics I currently own.
Thank you for the cable recommendation and I too am interested in the results with the Squeezebox paired to the BDA-1.  I do plan on sending in the Duet for one of the digital mods from Wayne at Bolder Cable co.  I will be curious to see how much of an effect the modification has on the sound quality.
werd
« Reply #4 on: 17 Apr 2009, 07:12 pm »
Hi Werd,
Hi Audio
 :lol: You have all the gear i want, especially those speaks. Own a pair of 104/2 (idle right now). loved them but i wanted those 205/2 you have. The same hifiplus issue that reviewed the pmc ob1 did your kef's also. http://www.hifiplus.com/issue63.html. i dont know if you can find the review on there buts its a great review saying it has all the same quality(drivers,etc) of its bigger bro but just smaller.
denjo
« Reply #5 on: 17 Apr 2009, 07:13 pm »
Empirical Design's 118 digital coaxial cable is fantastic value! I switched from Stereovox XV2 to Karl's digital cables and won't look back!
Robert D
« Reply #6 on: 19 Apr 2009, 01:25 pm »
Using Bryston Spdif coaxial as well Bryston Xlr Aes-Ebu Digital Cables, Great Sound !
drummermitchell
« Reply #7 on: 19 Apr 2009, 01:43 pm »
I'm thinking of trying the Bryston Xlrs,Im using Cardas grcs(rcas)
of course my longest run is around 3 meters,so i don't know if they will have any effect.
Sonic wise everything sounds great,but I never tried balanced before,maybe I'll recieve a nice surprize :scratch:..
Robert D
« Reply #8 on: 19 Apr 2009, 01:57 pm »
drummermitchell, I'm running from my BCD-1 to the BDA-1  2 Cables  1 XLR witch is or called a Aes-Ebu 1 Meter as well 1 coaxial Digital 1
meter as well. For the reason of beening able to switch depending on the recording of the Cd !
pardales
« Reply #9 on: 19 Apr 2009, 02:03 pm »
Do you have a link for this cable/company?
mcullinan
« Reply #10 on: 19 Apr 2009, 02:07 pm »
Call me crazy but I am using Silver Resolution Digital Coax... Full sound, Natural!! Open and very tangible. This with my BDA-1
Mike
« Reply #11 on: 19 Apr 2009, 02:09 pm »
Here you go:
http://www.empiricaldesign.net/
james
Robert D
« Reply #12 on: 19 Apr 2009, 02:22 pm »
pardales, Mr Tanner answered your Question.
drummermitchell
« Reply #13 on: 19 Apr 2009, 02:27 pm »
That would be interesting to try(AES-EBU)BCD-1 into BDA-1,+my BCD-1 analog outs to the BP-26.
Back to the audio sandbox,I wonder if a say,is a 2 meter to long for digital.
Here I was hoping my cable search was over.I think I'm going to try balanced and see.
And now there is BNC cable I'm assuming that would be for a sqeeze box or I-pod ,correct.
Robert D
« Reply #14 on: 19 Apr 2009, 02:42 pm »
drummermitchell, The BDA just opens The Doors, It's amazing ....if It's Kenny G or Emmylou Harris. The BCD-1 and BDA-1 combo is Great.
The Way it just Places the Instruments. I'm running 1 4Bsst2 to the Left Speaker and 1 4Bsst2 to The Right Speaker in Stereo.
The BDA just adds it's Touch. Try It
drummermitchell
« Reply #15 on: 19 Apr 2009, 02:51 pm »
I like it and I will,because we can,thanks :thumb:.
mr_bill
« Reply #16 on: 19 Apr 2009, 03:28 pm »
Denjo,
Please tell me more - I have the Stereovox XV2 digital cable.
How much better is the empirical design - what differences did you notice?
James - have you used this digital cable too?
niels
« Reply #17 on: 19 Apr 2009, 08:15 pm »
I normally dont participate in cable "discussions" but I have used the Stereovox XV2 for 3 years now. I havent done an A-B test, because I am pretty confident I wouldnt hear a difference from a 2 dollar "shoe string" rca cable....
rydenfan
« Reply #18 on: 20 Apr 2009, 03:16 pm »
Hi Werd,
Hi Audio
Werd, I just wanted to make sure you saw the PM I sent you  :D
