Help with screen
0 Members and 1 Guest are viewing this topic. Read 1123 times.
Nick77
Help with screen
« on: 17 Apr 2009, 04:29 pm »
Hi we were given this screen but dont know how to wire it or if its even worth keeping. It came out of an office and is approx 9' long and screen is approx 87". I am attaching a few photos for advise, ditch it now or is it of some value and can be utilized for HT screen when time comes?
Maybe it can be used as a manuel? Thanks for input.
Edit: I found some id, its a Draper access series V used for office display. They cost approx $1800 but I have no way of knowing what the screen is far as ratio is concerned. How would I find out aspec ratio and if it will work for HT? I dont know if I should keep or try to sell if possible?
Doublej
Re: Help with screen
« Reply #1 on: 17 Apr 2009, 11:29 pm »
Check here for install instructions and information about the screen.  If you wanted to use it, worst case you can probably take it apart and use it as a permanently in place screen though historically office screens have not been 16x9 format.
