0 Members and 1 Guest are viewing this topic. Read 17168 times.
Nice.. that's some great customer service too. I've got an AT-120E right now, thinking about upgrading either to the AT-440MLa or a AT-150MLX. I find the AT-120E a touch on the bright side, the above chart looks very promising for the 440.
mikeyvsmichael,What table are you using this cart on?Wayner
I'm tracking at 1.5 grams with this cartridge on all of my turntables. I think 1.4 might be a hair too low. I also have my anti-skate set at about 2.5 on the Technics SL-1200MKII. I have a blank disc and that is the number that makes the arm stand still. Try that once and come on back.Wayner
The blank disc is an excellent way and the only way to acurately set anti-skating. The skating forces on a tonearm are generated by 3 factors. First is the offset angle of the cartridge, second is the VTF and 3rd is the RPM. Yes the very tip of the stylus does not actually touch the record groove walls but the forces acting on it are the same. You can also see and hear the differences.Wayner
While some may claim the disc technique doesn't work, I strongly disagree. It is not perfect, but is a great tool to get you into the ballpark. One of the tonearms (RB300) is right on the money. 2 other tonearms are off only a slight amount from their supposed A/S positions.Wayner
There isn't a flat surface on the AT's bottom, so I don't know how you could determine that it's out of alignment in that plain. As far as off from design center and you said azimuth, isn't the stylus right between the void in the assembly? It almost sounds like the cantilever is bent. Or are you seeing this stuff when you are playing a record and maybe some adjustments of your tonearm are out of wack? AT will back up any warranty issues, no problem.Can we post pictures yet?Wayner
