Make sure I got this right ...
0 Members and 1 Guest are viewing this topic. Read 1481 times.
Laudanum
« on: 16 Dec 2003, 12:15 am »
Been reading the posts but just want to make sure I have this right ...
Regarding the Cornet, I will be using a hybrid integrated amp with the Cornet for the time being anyway.  The input impedance of the amplifier is 100K  so from reading, am I correct that with the 100K input impedance, I am probably better off leaving those output caps at .47 uf instead of going up to 1.0uf ?  My understanding is that with the 100K input imp. the .47 will pass ample bass and less rumble than a 1.0 uf ... probably too much subsonic/rumble freq. if I go to the 1.0 uf with the 100K input imp. ?
Also, I do have some inexpensive 400V Dayton branded polyprop. film and foils that I got from PE mainy for passive crossover bypass use.  Would these be worthy to try in the .47 output cap positions?
ps.  got my board already ... ordered last Thursday I think.  Came quicker than the parts ordered from the mainland.  Nice board Jim !  Thanks !
hagtech
    • http://www.hagtech.com
« Reply #1 on: 16 Dec 2003, 05:12 am »
Yes, you'll be ok with the 0.47uF.  Haven't heard of the Dayton caps.  You never know what might sound good!
jh :)
