One week with the new 4B-SST/2
0 Members and 1 Guest are viewing this topic. Read 2310 times.
danman
« on: 14 Apr 2009, 01:28 pm »
After almost a week of on-off listening I would like to give my views compared to my 4B-ST.
As I mentioned from the start, the 4B-SST/2 has much better mids and highs than before. At first I was not sure if it was my mind playing tricks on me but after listening to CD's I know well, it is more and more obvious.
This biggest difference is dynamics. With my Martin Logan Quests the older 4B-ST was great but needed to be pushed a little harder to produce those famous midrange sounds they make at low volume. The 4B-SST/2 however, promises the same sound at 1 watt as it does at 300 watts and this is a definate fact. Having 4 kids forces me to listen at resonable levels at night and the signs of a good amp compared
to a great one is low volume sound and knowing that the Logan's are a tough act, this amp can make them sing.
The amp runs very cool in comparison even at higher volumes so this tells me that the load my speakers demand does not seem to bother the amp at all compared to the ST which would get very hot but this may be characteristic as even at idle the ST would be very warm. Any heat is always to each side of the amp and none on top which means to me that the heatsinks are very well designed. The amp seems better adapted to different speaker loads.
I am running everything in 1 volt (balanced) right now and have not experimented with the 2 volt (balanced) setting. I want to get used to the sound as is before trying this but am not sure if I will notice anything besides a little less volume overall.
How does all of this sound to me? Well, the answer is quite simple. The amp is much more musical and quick. I have some friends with expensive YBA gear that (to my ears and even theirs!) sounds flat in comparison. They wish that the bass slam was as good. I know this because I owned YBA before and yes excellent but not very flexible sound wise. I am considered the black sheep of amps in my neighborhood because I am the only one that owns Bryston. Living in northern Quebec, there is no dealer close but I do travel a lot for business and this is how I discovered the brand. I have never been one to follow a trend or a brand just to be like the others. I have always trusted my ears more than anything and today the biggest problem with some is that they can't sit down and listen to the music instead they listen to the electronics!
Probably my next upgrade will be the MPS-2 for my BP-20. This would bring me very close to the BP-26 for a lot less money. I would also like to get the BCD-1 but I am not sure what lies ahead with CD's. My Cambridge Audio 840c is excellent but not as good as the Bryston but definately the closest I have listened to. The CA is a little dry in comparison. However, this will come all later as I want to listen to what I have now and make the right decisions and also the money factor because the 4 kids come first obviously!
I would like to thank many on this site and of course James for helping me make the right decisions on my recent purchases. To resume all this I would say that those thinking of upgrading to the new SST/2 series, go for it because it is definately worth it!
Cheers
1ZIP
Re: One week with the new 4B-SST/2
« Reply #1 on: 14 Apr 2009, 01:51 pm »
Mine should arrive in a couple of weeks....good to hear the feed back.  I am looking forward to hearing the BCD-1, BP-26, SST2 combination.  Plan on auditioning some PMCs this week, that should be interesting!
werd
« Reply #2 on: 14 Apr 2009, 07:34 pm »
Woot!!!! The 4bsq strikes again..... :guitar: Dangerous this amp is, lurking in the shadows waiting to jump and strike.... blow any audiophile away.
werd
« Reply #3 on: 15 Apr 2009, 03:43 pm »
Hi Danman
I think bal. is the way to go with this amp along with the 1v setting, but i am sure you will find that out. Trying running your Cambridge into the tape inputs of the bp-20 for further improvemt. The tape monitor is the nicest input on these pre's imo. The input is more linear because it by-passes the input switch.  If they ever made another pre  i would like to see bal. in and out of the tape monitors. I cant believe you can live without the remote control (i am such couch potato)  :lol:. I would recommend the the mps-2 if you had the bp-25. Just spring for the BP26 and get nice and fat like the rest of us .....  :lol:.
vegasdave
« Reply #4 on: 15 Apr 2009, 06:55 pm »
Cool review! I wish I could afford 1 of the new amps. I have my sights set on the new 7B's
alexone
« Reply #5 on: 15 Apr 2009, 07:28 pm »
Dave,
the new 7B's must be great amps! if i would have to choose between the 14 and the 7 I'd take the 7, cause of the mono design.
al.
danman
« Reply #6 on: 15 Apr 2009, 10:41 pm »
Werd, my Cambridge is all balanced out so I think I am better this way.
I don't mind not having a remote to be honest. Never even think about it.
