0 Members and 1 Guest are viewing this topic. Read 6606 times.
Thanks Niteshade I'll check it out Any schematics of an amp with this tube combination anybody out there has seen or better yet built?
I'm thinking compact GM70 monoblocks pure SET shooting for weight and focus.
Quote from: JackD201 on 25 Apr 2009, 04:33 amI'm thinking compact GM70 monoblocks pure SET shooting for weight and focus. I got to wonder why. Compact means that you can't use any of the components that really make a SET a SET, like big choke input chokes, motor run caps, VT rectifiers. Plus the GM70 has 60 watt heaters. If you want to build a long-lasting and reliable amp you must ensure space around the output tube especially so that heat doesn't cook your components. Most amps commercially build are a compromise, we diy'ers don't have to make such compromises. why would you compromise intentionally? If you intent to build compact gm70's, you will be using ss diodes, no big chokes, no seperated filament windings, electrolytic caps throughout. If that is the case I have to ask why bother?
