Bugle Direct to Amp
0 Members and 1 Guest are viewing this topic. Read 1752 times.
wushuliu
Bugle Direct to Amp
« on: 14 Apr 2009, 05:41 am »
Hope this isn't a stupid question: I have pre-outs from my Marantz receiver to an Audiosource Amp 3. Is it okay for me to just run the Bugle directly into my Audiosource Amp 3, or should I pass it through the aux of my receiver?
reuben
Re: Bugle Direct to Amp
« Reply #1 on: 14 Apr 2009, 02:58 pm »
You need to use the Aux inputs of the receiver, or, as a bare minimum put an attenuator (volume control) between the Bugle and the amp.
Tom
wushuliu
« Reply #2 on: 17 Apr 2009, 08:11 pm »
Thanks. The Audiosource has volume control so need I believe to worry about attenuation. I went ahead and patched the Bugle directly to the amp, the sound is much improved over the receiver aux inputs.
