Need opinions on this.
0 Members and 1 Guest are viewing this topic. Read 1142 times.
magsterone
« on: 13 Apr 2009, 08:28 pm »
     My room is 30'l x 18'w. It has one door at the far end and opens to the kitchen thru an opening at the other end. All along one side it is open to a room of the same dimensions.
     My current plans are to get parasound separates 5125 5 ch 125 w per ch amp with the hdp70 processor. I am leaning toward von schweikert vr 4jr's for my fronts. I already have their lcr 15 as a center and mb quart as surrounds. What is your opinion on this? Should I go for their 250 w per channel amp? I mainly listen to music but I do plan to use the system for home theater. Any opinion is appreciated.
      Also, how much difference is there bewteen the parasound A52 as compared to the 5125?  Is it worth the difference?
Joe in Mobile
phoenix_rising
Re: Need opinions on this.
« Reply #1 on: 21 Apr 2009, 07:45 am »
Joe in Mobile
I am not sure about the efficiency of your speakers but you select speakers and amps to handle at least 110-115db peaks at the listening position.
magsterone
« Reply #2 on: 21 Apr 2009, 06:37 pm »
I am willing to appear uniformed, but how would I know if they are capable of that?  By their spec's from the manufacture?  Or how would I know how output rec'd at the listener's position?
Joe in Mobile
