0 Members and 1 Guest are viewing this topic. Read 4128 times.
...plenum rated Cat5 network cable. If you need 10ft speaker cables, get 10 ft. Be sure you get plenum rated, as it has excellent sounding teflon insulation. PVC is yucky. Strip it apart. Use one twisted pair for each speaker.
do you like to raise the inductance by untwisting and using a spaced pair? Packing tape works real well for that.
