0 Members and 1 Guest are viewing this topic. Read 3644 times.
A multimeter is only going to give you the DC resistance of the speaker. That is not the same as impedance, which varies with the frequency of the signal. Speakers have peaks and dips in the impedance, so the "nominal" 4 or 8 ohm figure that you normally see is kind of a "safe bet" territory. The impedance may drop below 8 ohms (or whatever other figure given) but not by much and only for a limited range. Focals are a well regarded speaker so I doubt the impedance figure given is wrong. I'd hazard a guess, based on limited info, that the focals are not as efficient as your old speakers. You may be driving the amp much harder to reach the same room volume as the old speakers. Another possibility is that your Denon had developed a problem and the new speakers put just enough of a demand on the amp to turn a problem into a failure. How old was the Denon?
Alright got my Focal's in today they sound great, or should I say, sounded great. Only had them on for maybe a hour went to do some cranking normal LOUD levels with the previous 20 yr old pieces of **** no problems with them.Than the receiver goes into protect mode. I let it cool down with a fan in fact for a bit. Turned it back on and it sparked heavily twice very fast. I couldn't turn it off quick enough not that it matters. I even think I saw a small flame burst. Well it's fried for sure!!!!!!The Focal's say they are 8 ohm but putting a Multimeter on them they read a constant 4.6 ohm. Is that normal when brand new or are they just labeled wrong or am I just an idiot who needs to shoot himself in the mother****ing face?Oh and the reciver in question is a Denon 2106, 6 ohm
............<snip>............. Translated into english.............<HUGE technical snip>............
And yes the reciever is about 5-6 yrs old. Thing is I just had it fixed beause I blew it up about 6 month's ago...
Time to look for a new recv'r or pre\pro. Not quite sure what I want at this point, this came on too suddenly.
Quote from: gixxerific on 9 Apr 2009, 01:57 amTime to look for a new recv'r or pre\pro. Not quite sure what I want at this point, this came on too suddenly. It sucks that your Denon died. Tell you what, over on AGon there is a Arcam AVR 100 for $350 bucks. It's a darned fine sounding 5.1 receiver. I've had one for about 8 years. Nice clean (but not sterile) sound, good bass and it even has a pretty OK internal DAC (non-oversampling). Granted, its only 85w x 2 but it should drive the Focals just fine.If you go for it I think you'll find you like its sound much better than the Denon.
Well, if it's just the amp section that's toast, you could potentially just use the pre-outs and get an external amp.Bryan
