Modwroight Sony 9100ES Failure to Read SACD
0 Members and 1 Guest are viewing this topic. Read 1395 times.
Vicks7
« on: 6 Apr 2009, 08:00 pm »
Hi All,
My modded 9100ES has suddenly stopped playing SACDs or the SACD layer on Hybrid Discs - the message on the display is "Cannot read disc". It is still playing regular CDs.
Has anyone experienced a similar problem - I assume it is the laser although I have not put that many hours on the player so I am disappointed to say the least.
Thanks in advance
James
DTB300
Re: Modwroight Sony 9100ES Failure to Read SACD
« Reply #1 on: 6 Apr 2009, 09:18 pm »
Could be you need a new laser assembly, which Dan can do for you.  But it just may be a simple clean and lube of the sled to fix it.  First time my player went to Dan for some mods, I had him clean and lube.   Then when I had more mods done, I had a new laser assembly installed just for good measure and Dan sent me back my old one (fully functional) in case I needed a spare for the future.
