electrical efficiency: ICEpower vs. solid state vs. tubes ?
0 Members and 1 Guest are viewing this topic. Read 1468 times.
grsimmon
  • Omni - the best way forward
I'm familiar with the efficiency of ICE amps such as Bel Canto,  Rowland,  etc.   I'm wondering (generally speaking) how do tubed amps and solid state amps compare to ICE and each other with regard to efficiency?
JimJ
  • Ut Prosim
Re: electrical efficiency: ICEpower vs. solid state vs. tubes ?
« Reply #1 on: 6 Apr 2009, 08:01 pm »
Poorly, but in a home, I wouldn't be worried too much about efficiency unless you're running multiple kW amplifiers for subwoofers.
Class A/B has a theoretical maximum of around 78%, but driving low impedance loads can significantly reduce it. SE tube amps in Class A are well below that.
Rasta
« Reply #2 on: 6 Apr 2009, 08:30 pm »
You can tell by the amount of heat, light and other by products given off by the unit.  So generally, the more heat given off. the less efficient the device.
