0 Members and 1 Guest are viewing this topic. Read 79763 times.
... In my system, the particular SS pre was far more musical then either of the tube pre's. It has less leading edge attack and more of a silken texture. This was truly an eye opening experience for me as previously I truly would not have thought this possible. It just helps to further instill in my stubborn brain that I should never make any assumptions or pre-conceived notions in this hobby, and always let my ears make the decision.
I can not view why a sane person will prefer use a SS music amp
As Iam not radical, in last case I can accept a SS amp, since it is Class A output, because without alot of heat there is no sound quality.Sincerely, Full
The three best systems I've heard (including my reference, the Sonicweld Pulserod system) were all driven by solid state amps. They were all well in excess of $100k though...Peace, Lee
Quote from: rydenfan on 5 Apr 2009, 01:53 pm... In my system, the particular SS pre was far more musical then either of the tube pre's. It has less leading edge attack and more of a silken texture. This was truly an eye opening experience for me as previously I truly would not have thought this possible. It just helps to further instill in my stubborn brain that I should never make any assumptions or pre-conceived notions in this hobby, and always let my ears make the decision. What SS Pre did you audition?
Quote from: sleepysurf on 5 Apr 2009, 03:35 pmQuote from: rydenfan on 5 Apr 2009, 01:53 pm... In my system, the particular SS pre was far more musical then either of the tube pre's. It has less leading edge attack and more of a silken texture. This was truly an eye opening experience for me as previously I truly would not have thought this possible. It just helps to further instill in my stubborn brain that I should never make any assumptions or pre-conceived notions in this hobby, and always let my ears make the decision. What SS Pre did you audition?Feel free to shoot me a PM. I wouldn't want to hijack the thread or anything. I am already on thin ice saying I preferred an SS pre to a tube pre in the Tube Circle
Fullrange, you seem to be a very strongly opinionated person. I agree with some of what you say but not all; however, I am not to sure that you are into opinions that differ from yours. You call Pass labs over priced compared to a Jolida yet the Pass Labs XA30.5 stereo amp is under $6,000 with 30 watts of pure Class A. Plinius as well offers a wide range of amps. You dont believe tube amps get updated over time? You specifically mention Atma-Sphere; why do they have Mk.2 and Mk.3 versions of pieces if they are not further developing and refining tier product? A little diplomacy goes a long way here...
now you'reDriving sidewaystaken in by the sceneryas you're propelled alongAnd your companionwill not help you to navigatefor fear she may be wrongAnd you will saythat you're making headwayand put it in overdrivebut you're mistaking speedfor getting what you needand never even noticingyou never do arrivecause you'reDriving sidewaysif you roll down the window you'll seeyou're where you don't belong
Some time ago there was a SS/tube amp shoot out. I believe the listening was done blind. There were some very good tube amps--Dodd, etc. etc. One SS amps thrown in was a pair of Odyssey Extreme Monoblocks.Guess what amps a good majority of the people preferred by a fairly wide margin?The Odyssey's.
