neo-2x phase question
0 Members and 1 Guest are viewing this topic. Read 1185 times.
baald
« on: 31 Mar 2009, 08:00 pm »
this may have been covered elsewhere, but not sure what phrase to query on, so forgive me....
(using neo-2x as example as that's what i'm interested in)
What are the effects of the BG tweeter not being co-planar with the woofer VC?
is it accounted for in the x-over?
is it a philosophical difference that Danny (or other designer if applicable) feels is negligible?
What would happen if using the existing x-over, one built the speaker to make the tweet coplanar with the woofer VC?
baald
Danny Richie
    • http://www.gr-research.com
Re: neo-2x phase question
« Reply #1 on: 1 Apr 2009, 02:59 am »
Driver offset is accounted for by the crossover.
Then the drivers would be out of phase.
