Niteshade NS-3 Special Edition SALE!
0 Members and 1 Guest are viewing this topic. Read 3151 times.
Niteshade
    • Niteshade Audio
« on: 30 Mar 2009, 02:36 pm »
Want something special to try?   :D
$440.00 Delivered within the Lower 48
As beautiful to look at as to listen to. If this model were in the supermarket food section it would be labeled, “100% Organic”. Single ended amp lovers enjoy an organic tonality. One of the best ways to portray that quality is through the use of EL84's. Other adjectives that come to mind include: Liquid, smooth, easy to listen to and even sensual. Music flows around the listener. It's not aggressive or harsh. You will notice a control on the front. That's for a circuit I designed called Variable Negative Feedback. I made it so you can contour the amplifier to your speakers. Not too many amplifiers have such a feature. Normally people are stuck with what the amp puts out. Now you have the power to mold the amp into your system. The NS-3 produces three watts per channel of class A power that's ideal for speakers 95db sensitive and up. You will NOT find a better amplifier for horn loaded speakers. We covered the amp in Maple Autumn Metallic- eye candy for certain.  For more information on Niteshade Audio, please use a search engine. It's easy to locate.
« Last Edit: 5 Apr 2009, 11:47 am by Niteshade »
Ericus Rex
Re: Niteshade NS-3 Special Edition SALE!
« Reply #1 on: 30 Mar 2009, 11:11 pm »
So this beauty is 3 watts/side?  What does the chicken knob adjust?
Bemopti123
« Reply #2 on: 30 Mar 2009, 11:34 pm »
The Chicken does volume control or gain?
Niteshade
    • Niteshade Audio
« Reply #3 on: 30 Mar 2009, 11:41 pm »
Hello-
The knob is for adjusting negative feedback. It doesn't control volume. If it were a volume control, the amp would be integrated- but I opted for the feedback control instead. The good news: It can be made into an integrated amp!
Blair
jon_010101
« Reply #4 on: 31 Mar 2009, 12:03 am »
Just curious, How many dB is the feedback variation min-to-max?  Do you compensate for that gain change with a second pot on the same shaft, or does the overall closed loop gain change accordingly?
Niteshade
    • Niteshade Audio
« Reply #5 on: 31 Mar 2009, 12:23 am »
The feedback goes from near zero to about -20. There are no gain adjustment pots ganged with the feedback control for compensation. The amplifier will arrive with the gain control pre-calibrated at the 12 O'Clock position for best performance.
Niteshade
    • Niteshade Audio
« Reply #6 on: 1 Apr 2009, 10:44 pm »
Our NS-3 Special Edition is made for those looking for that classic, warm tube sound via El84 delivery.  I have made these in the past and received rave reviews, then decided to prototype a model with variable negative feedback a little while ago. The combination is unbeatable!
$440.00 DEILVERED  :D
Niteshade
    • Niteshade Audio
« Reply #7 on: 3 Apr 2009, 07:24 pm »
$440.00 Delivered   :drums:  :banana piano:
Classic, warm El84 tube signature tone. Three watts per channel. Exceptional delivery quality.
Want a different color? No Problem! This one is available for immediate delivery.
Free Delivery for the Lower 48.
Niteshade
    • Niteshade Audio
« Reply #8 on: 7 Apr 2009, 10:42 am »
Ideal for efficient speakers in the 95db and up range. That includes horns, many single driver systems and such. To insure a perfect fit in your system, variable negative feedback was installed.
This is a fun to use amplifier! It's gentle on the tubes, produces so little heat it's not worth mentioning and does carry a vintage El84 tone signature: Smooth, organic, flowing, not in your face. It's an amplifier to relax with.  If you're into vocals, the midrange is impeccable! Lows and highs are smooth as silk.
I can guarantee there is no better amp for classic single ended EL84 tone- straight from the 50's and 60's.
If you would like a bigger rendition- that can be done as well. We have a 40lb transformer package that's used with the NS-10.  :drool:
Instead of using a single El84, they can be paralleled. Sound quality is not sacrificed and the wattage is increased.
Niteshade audio is your custom design headquarters.
Niteshade
    • Niteshade Audio
« Reply #9 on: 12 Apr 2009, 01:17 pm »
I'd put it on sale, but then it would be almost free.  :D
Low cost, virtually NO heat output, pure vintage El84 sound.
$440.00 delivered to the Lower 48!  :drool:
HAPPY EASTER!
tvyankee
« Reply #10 on: 12 Apr 2009, 03:29 pm »
hello
this does not have to do with your sale but was wondering if you could build a integrated amp that would be 100 watts per channel into 8ohm's  and costs under or about $2000.00?
thanks
Niteshade
    • Niteshade Audio
« Reply #11 on: 12 Apr 2009, 03:48 pm »
Hi- I just sent you a message.
hello
thanks
Niteshade
    • Niteshade Audio
« Reply #12 on: 12 May 2009, 12:29 pm »
7 Day Trial for AudioCircle Members!
Niteshade
    • Niteshade Audio
« Reply #13 on: 13 May 2009, 11:17 am »
There are several upgrades available for the NS-3.
Please call or email for information.
The NS-3 is the IDEAL amplifier for horn loaded speaker systems.
Niteshade
    • Niteshade Audio
« Reply #14 on: 20 May 2009, 01:18 pm »
The NS-3 is sold!
Niteshade
    • Niteshade Audio
« Reply #15 on: 28 May 2009, 12:44 pm »
If you would like a basic single ended amplifier good for horns & high efficiency speakers- let me know. Low watt single ended deigns are a specialty of mine.
