Other Stuff
Archived Manufacturer Circles
DIY Cable
DIY Headphone extension cable
BobM
29 Mar 2009, 07:27 pm »
Does anyone have a recipe for a DIY headphone extension cable? I really don't want to buy a new long Sennheiser replacement cable and would be more inclined to get 10' of good bulk cable and put on some decent Neutric connectors.
Bob
Kevin Haskins
Re: DIY Headphone extension cable
30 Mar 2009, 03:13 pm »
You could use some Canare L-4E that has four stands as an inexpensive cable to build a headphone cable. Most of my customers building something are using the Cardas 4x24 which is the same basic cable as used in the headphone cable but uses a different jacket. It is also used in the phono cable I build.
Other Stuff
DIY Cable
