HTC specs
0 Members and 1 Guest are viewing this topic. Read 1509 times.
floresjc
HTC specs
« on: 29 Mar 2009, 05:32 pm »
Can anyone post the physical dimensions and recommended power requirements (at 4 or 8 ohms) for the HTC? The Salk webpage has no "specs" for this particular speaker, and I want to figure out if it'll fit in my existing center channel stand.
Philistine
Re: HTC specs
« Reply #1 on: 29 Mar 2009, 05:46 pm »
Here you go:
Width 23"
Depth 14"
Height 10.25"
This is a 4 ohm design, don't know the power rating.
I had an old B&W Nautilus center channel stand and sent Jim the fixing plate, which he then incorporated into the HTC.  The value of custom design :thumb:
floresjc
Re: HTC specs
« Reply #2 on: 29 Mar 2009, 06:05 pm »
Appreciate the info. I don't think its too hard to drive, seeing as there's no massive woofer in it. The dimensions were most important to me, thanks a million for the info!
mcallister
Re: HTC specs
« Reply #3 on: 30 Mar 2009, 09:47 am »
while on the topic of the HTC what is the frequency response of it?
fsimms
Re: HTC specs
« Reply #4 on: 30 Mar 2009, 01:05 pm »
It is my understanding that the center with movies is just voice only.  Please correct if my info is dated.
Bob
skeeter99
Re: HTC specs
« Reply #5 on: 30 Mar 2009, 05:11 pm »
Bob, that is not correct. The majority of sounds for movies come from the center channel. This % of course ranges from film to film but in a HT environment, I'd say your center channel (or ability for your mains to throw a good phantom center) is one of the, or the most, critical element. A good center channel, or phantom center, is a wonder and increases the movies interactivity and realism immensely.
Scott
