Tonearm Static Shock
0 Members and 1 Guest are viewing this topic. Read 2199 times.
mhconley
« on: 28 Mar 2009, 07:53 pm »
I have an Opera Consonance LP-2.0 turntable, a Mørch UP-4 tonearm and a Grado Sonata high output phono cartridge.  The LP-2.0 turntable has a 67mm thick solid acrylic platter and a heavy solid aluminum base sitting on aluminum cones.  See it here: http://www.opera-consonance.com/products/reflp20.htm.  The turntable is on a wood shelf.
Every time I play an album I use a Discwasher brush and fluid to clean it then zap it three times with my Zerostat.  I use a Thorens stabilizer to couple the album to the platter.
My problem is that when I lift the tonearm at the end of an album side I get a strong static shock from the tonearm.  The tonearm hook-up is properly grounded to my Parasound Halo P 3 preamp.
Is this normal?  Is there something I can do to eliminate this unwelcome zap?
Martin
Wayner
Re: Tonearm Static Shock
« Reply #1 on: 28 Mar 2009, 08:01 pm »
Your Zero-Stat is loading the LP. You don't need to Zap it 3 times. In fact, you shouldn't be zapping the LP on your table. Do it off of the table and you don't have to do it everytime. Your turning your lp into a gigantic disc capacitor. The only way for it to discharge is when you take off the stylus.
Also you have a good chance of damaging your cartridge coil windings if the zap is big enough. There are others here at the AC that have done that very thing.
Wayner  :D
BobM
« Reply #2 on: 28 Mar 2009, 10:02 pm »
I ran a thin wire from a grounding point (i.e. cold water pipe, radiator, AC grounding lug, etc.) near my rack to a location on the top of the rack where I mounted a bolt in easy reach. every time I go to touch anything on the rack I touch this wire and "discharge" (the static you bonehead, not the flatulance).
Bob
orthobiz
« Reply #3 on: 28 Mar 2009, 10:46 pm »
That's why I touch my speaker grille first instead.
Then I touch the base plate of my turntable.
Then I touch the tonearm.
And I can still get shocked. Three times. But the tonearm is the least.
Only my Van Alstine volume remote prevents me from getting shocked EVEN MORE!!!
Paul
analognut
« Reply #4 on: 29 Mar 2009, 08:48 pm »
This news is all really shocking!
Here we have one fellow who gets shocked not once, but 3 times!
I upgraded to a Sota Star/ SMEV/ DL103R from a Pro-ject 2.9/ Pro-ject 9/ X5MC,
and the only shocks I get are good ones when I listen to my records!  aa
mhconley
« Reply #5 on: 31 Mar 2009, 02:10 am »
I think it is rather shocking also.  I thought the Zerostat was a static reducer, not a static builder.  I think I'll play with some grounding schemes.  And possibly invest in a Staticmaster brush.
Martin
