For Sale: Speakers & Speaker Stands
FS: 2 Ascendant Audio Atlas 15" Subwoofer Drivers- Brand New in Box - Sold!!!!
0 Members and 1 Guest are viewing this topic. Read 2800 times.
howburger
27 Mar 2009, 08:59 pm »
I have 2 Ascendant Atlas 15" Subwoofer drivers that are Brand New in Box. I built my IB 3 years ago and used only some of the 8 drivers that I bought. They originally sold for $160.00 each. They have been stored inside my house in a climate controlled spare bedroom. There are numerous enclosure recommendations online for use as a boxed sub. They are dual voice coil and are configurable as low, medium or high QTS, depending on your application. They excel at Infinite Baffle installations and I'm sure will make a good open baffle (Sub)woofer as well. I am looking for $100.00 each for them plus shipping from zip code 92019 at about 25 Lbs. each in box.
Harold
Low Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .392
Qts .37
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 11.7
Spl 1W/1M 91.5 dB
Spl 2.83V/1M 95.5 dB
Le .86 mH
Cms .388 mm/N
No. .904
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
Mid Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .483
Qts .45
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 10.3
Spl 1W/1M 90.6 dB
Spl 2.83V/1M 94.5 dB
Le .86 mH
Cms .388 mm/N
No. .711
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
High Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .624
Qts .57
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 8.5
Spl 1W/1M 89.5 dB
Spl 2.83V/1M 93.5 dB
Le .86 mH
Cms .388 mm/N
No. .567
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
Last Edit: 30 Mar 2009, 04:35 pm by howburger
