Power supply
0 Members and 1 Guest are viewing this topic. Read 1929 times.
LFE
Power supply
« on: 26 Mar 2009, 03:52 am »
Hello all, I am not sure if this is the right forum for this question, but here it goes:
Can anyone recommend a high quality power supply with the following specks:
Input: 120VAC 60Hz 38W
Output: 24VAC 500mA
With a barrel connector on the end?
I need one that is high quality and low noise. Do you know of anyone who makes custom PS?
dweekie
Re: Power supply
« Reply #1 on: 26 Mar 2009, 04:11 am »
What are you powering?  Are you sure the output isn't 24VDC instead of 24VAC
LFE
Re: Power supply
« Reply #2 on: 26 Mar 2009, 04:21 am »
It is a mic preamp for recording. I was looking around for something other than the walwart it came with, I figured if there was any place to find an audio related PS it would be found on the circles!
Occam
Re: Power supply
« Reply #3 on: 26 Mar 2009, 07:55 pm »
Output: 24VAC 500mA
With a barrel connector on the end?...
38watts input and 12watts AC output? Sumth'm ain't right.
Would you please tell us the specific brand and model # of the mic preamp so we can do some digging.
peranders
Re: Power supply
« Reply #4 on: 9 Oct 2009, 01:38 pm »
38W may stand for 38 VA?
f2a
Re: Power supply
« Reply #5 on: 16 Oct 2009, 08:01 pm »
hi
is it phontom mic preamp  ? :)
Paul Hynes
    • http://www.paulhynesdesign.com
Re: Power supply
« Reply #6 on: 18 Oct 2009, 10:49 am »
Hi LFE,
If you have not yet found a solution to your microphone preamp power supply requirement, I can help you as I have a lot of experience powering microphone preamps. If you wish to talk further just PM me.
Regards
Paul
JimJ
  • Ut Prosim
Re: Power supply
« Reply #7 on: 18 Oct 2009, 03:02 pm »
Maybe these guys would have something that works?
http://www.surplussales.com
Lots of surplus PSUs, may take a little kludging to get the right connectors and things, though.
