0 Members and 1 Guest are viewing this topic. Read 6761 times.
Even though I chose a high output moving coil cartridge (ZYX @ .48 mv),
Depending on the gain of your preamp, you may be able to run a low output MC directly. My SP14 has 46db of gain in the phone stage and another 20 db in the line stage. Plenty of gain for my .23mv Dynavector.Russ
Well I think I'm going to go the LOMC route and pick up a Hagerman Piccolo project as the step up. Lots of great things said about this active gain stage, even beating out the well regarded S&B TX103 transformers. And the whole kit will probably only run me about $200, some time and solder.Thanks guys,Bob
I have been thinking about building a Hagerman Piccolo, I am running a Paris Head amp from Aspen Amp with very good results I would like to compare the two. ED
No tubes in a Piccolo - JFET's.
