phono cable
0 Members and 1 Guest are viewing this topic. Read 1492 times.
Derockster
phono cable
« on: 22 Mar 2009, 06:40 am »
Hi guys,I'm putting this out there for the more technically minded amongst us.I'm thinking of building a phono cable with homegrown silver cable.I'm planning to use their 30 gauge solid core silver cable.Any thoughts opinions or suggestions are greatly welcomed and appreciated.Regards Cleaton
pas
Re: phono cable
« Reply #1 on: 22 Mar 2009, 01:20 pm »
The standard appears to be 33ga stranded litz type wire.  I suspect that 30ga solid silver will be too stiff for the tonearm to track properly.  What kind of a tonearm are you going to rewire?
twitch54
Re: phono cable
« Reply #2 on: 22 Mar 2009, 01:36 pm »
I'm not sure the Op is rewiring his tonearm, rather from table to phono-pre ??
Derockster
Re: phono cable
« Reply #3 on: 22 Mar 2009, 03:37 pm »
Yes the op is from TT to phono pre.
twitch54
Re: phono cable
« Reply #4 on: 23 Mar 2009, 01:30 pm »
then I see no reason why your 'homebrew' won't work........"keep it short , keep it shielded"
Derockster
Re: phono cable
« Reply #5 on: 24 Mar 2009, 02:16 am »
Thanks Dave. :thumb:
