Airport Express and FM Streaming
0 Members and 1 Guest are viewing this topic. Read 1864 times.
rtate
« on: 18 Mar 2009, 11:30 pm »
Will the AE stream FM radio to a remotely located integrated amp or
do I need a Squeezebox to acomplish this??
They don't seem to mention this on the web site...
Watson
Re: Airport Express and FM Streaming
« Reply #1 on: 19 Mar 2009, 12:32 am »
It won't stream FM radio at all. There's no FM radio receiver.
It will stream web radio stations that broadcast in MP3 or AAC. It won't stream web radio stations that broadcast in WMA.
rtate
« Reply #2 on: 19 Mar 2009, 12:35 am »
What type of FM does the squeezebox do??
JerryM
  • Where's The Bar?
« Reply #3 on: 19 Mar 2009, 12:43 am »
Watson is correct. However, if you are using iTunes to broadcast to your AE unit, and your favorite FM station has streaming content for the internet, you can add that station to iTunes. It's easy:
  • While iTunes is running, choose Advanced > Open Stream.
  • Enter the URL for the Internet radio station's stream in the Open Stream window's URL field.
  • Click the OK button.
This will automatically add the station to your chosen library. Double click the station name and there ya' go; streaming FM radio!  :thumb:
Have fun,
Jerry
rtate
« Reply #4 on: 20 Mar 2009, 05:14 pm »
Jerry, I tried to add the URL but the radio station does not appear in my library.
This is what the url looks like:
http://corusmedia.media.streamtheworld.com/player/Player.htm?id=cilqfm&city=Toronto&bdskey=4831&url=http://www.q107.com&platform=EMMISFM&active=true
does this look ok to you?? or do I need to edit it?
low.pfile
« Reply #5 on: 20 Mar 2009, 05:50 pm »
rtate,
I am no expert on streaming.
But I checked out the link for classic Q107, That appears to be a Flash media type streamer. That cannot be played within iTunes. As Watson states below,  AAC, MP3 is needed for iTunes playback. you can add any broadcast using those media formats even if it is not previously listed in the Radio section of iTunes.
Though, you can send flash format audio and any sound format to you Airport Express, using a "hijacking" app- these are legal, they are just routing the audio files to your AE. On mac I use Airfoil by Rogueamoeba. This is not a free app (though a trial exists). There must be an equivalent for Windows OS. you haven't stated whether you are on mac or PC.
Some stations offer an option of WMA, Flash, iTunes, or Real format, though that is not common.
ed
rtate
« Reply #6 on: 20 Mar 2009, 05:58 pm »
I have a PC with XP pro as an operating system.
Where can I find these"hijackinf" apps??
low.pfile
« Reply #7 on: 20 Mar 2009, 05:59 pm »
Actually Airfoil is available for Windows:
http://rogueamoeba.com/airfoil/windows/
