Getting recorded audio into a Mac
0 Members and 1 Guest are viewing this topic. Read 1255 times.
avahifi
    • http://www.avahifi.com
« on: 18 Mar 2009, 04:25 pm »
All I want to do is to dump the contents of a little digital voice recorder that does not have a computer port into my Mac (that does not have an audio in port) to save the recording.
The voice recorder has a 3.5mm analog headphone out minijack.  The Mac of course has both USB and Firewire in.  OS1.4x
What is the minimum hardware, cables, and or software I will need to do this?  To me iTunes is a confusing nightmare to use.
Any help with this out there.
I do own a Canopus ADVC-100 video and audio A to D and D to A converter, which Canopus tells me I must have connected to a VHS video in, while connecting the voice recorder to the audio in, and then from the digital out from the Canapus to a USB in on the Mac.  I can try that, but what software do I need to actually make the recording on the Mac?
Thanks for your attention. I would really like to dump the voice recorder as soon as possible so it can be reused.
Frank Van Alstine
This new fangled stuff is getting beyond me.
Crimson
Re: Getting recorded audio into a Mac
« Reply #1 on: 18 Mar 2009, 04:29 pm »
A 3.5mm M-M from your recorder to the line in on your Mac, and Audacity will do the job.
avahifi
« Reply #2 on: 19 Mar 2009, 08:59 pm »
Thanks for your help.
Audacity and a 3.5mm connection cable, one end mono, the other stereo, did the trick.
That will now let me get audio from any old audio source into the Mac in a useable format.
Best regards,
Frank Van Alstine
