LG LH-T6740 - speakers ONLY
0 Members and 1 Guest are viewing this topic. Read 1618 times.
AV Guys
  • AV Guys (my hubby and me), totally into AV :)
« on: 16 Mar 2009, 07:14 pm »
Home theater speaker set (super slim towers, center and (passive) woofer speaker). Part of the LG LH-T6470 home theater system. Our receiver has stopped working and so we had to replace with a new Onkyo Home theater system but these speakers are too good to be left unused. Our loss – your gain.
The 4 towers (left/right fronts, left/right rears) are identical, measuring 2 ¾” x 2 ¾” x 47 ¼” / 6.2 lbs (7 cm x 7.2 cm x 120 cm / 2.8 kg)
each speaker uses 4 x 2 ¼” woofers and a single ½” tweeter.
The center speaker has same components in a compact center channel enclosure, measuring 2 ¾” x 2 ¾” x 20” / 2.5 lbs (7 cm x 7.2 cm x 50 cm / 1.1 kg)
The subwoofer has a single 6” element and measures  7 10/16” x 19.5 cm x 41.7 cm x 38 cm / 7.2 kg 16 ½” x 15” / 16 lbs
Note: as written above, this entire set (including the subwoofer) are all passive, meaning they require amplifiers to work. The speakers are all 6ohm, the subwoofer is 4ohm. They will work with almost any home theater receiver or multichannel amplifier.
They are nearly spotless, with only some minor blemishes on the towers’ bases and a single nick (please see @ http://picasaweb.google.com/our.ebay.photos/LGLHT6740Speakers#).
As you can see from the pictures, each tower speaker is made up of two sections. All speakers will be carefully packed and shipped in a single box 19” x 19” x 27” / @50 lbs
Asking $100.00 plus shipping, via PayPal. Offers welcome.
Please note: this item is also advertised locally and we reserve the right to end this post at anytime due to local sale.
(note: following specs are of the entire home theater system – I’m only selling the speakers)
http://www.backoffice.be/prod_uk/LG_Electronics/lh-t6740_lg_lh-t6740_home_theatre_system_5.1_channel.asp
AV Guys
Re: LG LH-T6740 - speakers ONLY
« Reply #1 on: 19 Mar 2009, 02:20 pm »
Hi,
The speakers we sold locally.
Regards
Ellen
