Has anyone experienced a electronic sound while connected to usb?
0 Members and 1 Guest are viewing this topic. Read 1800 times.
kazsud
Not sure if it only does this while charging but i never noticed it before in the 2.5 weeks i have owned it.
BTW it is connected to a Alu MacBook
kazsud
Update: It stopped doing it. Not sure if it is because is was super low on juice or because i rebooted my computer
jdmcderm
I have owned my IM for about 2 weeks and have about 30 hours on it.  I've used both the 1/8" and the USB connection and started to notice a high pitched whine when connected via USB.  I am also using an aluminum MacBook Pro.  At first it was intermittent and tonight I can't seem to make it go away.  It makes the DAC completely unlistenable.  I'm willing to experiment and/or see if it goes away, but am not overly hopeful.  Any help is appreciated.
Cheers
kazsud
Mine came back for 5 mins and I think it is the USB cable. I'm am going to pick up a better shielded one soon
rustydoglim
    • www.nuprimeaudio.com
If you have an iphone next to it, it will cause RFI from time to time.  This is widely reported online.
My iphone caused W-1 to make tee-tee-tee sound from time to time.
Jason
lifesundeath
For my Icon Mobile, I have sort of figured out what is causing this and how to work around it.  It's the battery charging.
The work around is sort of stupid thought.  Just plug in your headphones to turn it on then plug it in to USB and it should light up the white USB activity light and not start charging.  Here's the stupid: sometimes if it's been sitting for a while and you do this it will got to Green charge light on before the USB sees it and so you'll have both one (which also happens if you don't plug in headphones first and then USB).  In this case just unplug it from USB and plug it back in again and you should only have the Blue and White light on, no more high pitch whining noise.  It's really odd though because the noise only happens when it's charging, but when it's charging it doesn't always happen...hopefully they will release some firmware updates on this.
Cheers!
-d
« Last Edit: 25 Apr 2009, 07:05 am by lifesundeath »
Daeder
My icon/s1 makes RFI noise when I get calls coming in. It seems to happen when there are signals coming in and out made from my iphone. Now my W-1 is another story. I can't even have it near it or it starts going crazy. So when I'm listening to music and I get a phone call or text, my w-1 starts making RFI noise.
To avoid I just keep phone a few reaches away and it seems to do the trick. Now to make it stop... I don't know... :(
rustydoglim
We will look into the Icon Mobile charging while playing issue. May be it is a defective battery or charging circuit since only a few people reported this problem.
For the iPhone RFI issue, it is widely reported on the web. The RFI affects every audio devices. There is a widely used shielding solution using aluminum foil. I am sure you can find it with a search on the web.
Jason
Daeder
Yeah it happens to every audio device.
