Octal Adapters for Modwright Transporter
0 Members and 1 Guest are viewing this topic. Read 2911 times.
Wayne1
« on: 14 Mar 2009, 05:22 pm »
Octal adapters for use with the Modwright Transporter can finally be ordered from the BOLDER Cable website.
Here is a direct link to the web page for the adapters.
zybar
Re: Octal Adapters for Modwright Transporter
« Reply #1 on: 14 Mar 2009, 07:18 pm »
To my ears, these are a MUST HAVE for any Modwright TP owner out there.
You haven't heard what your TP is really capable of till you try some 6SN7 tubes in place of the 9 pin ones.
Thanks go out to Wayne for building them and Dan for supporting it.
George
rydenfan
« Reply #2 on: 15 Mar 2009, 03:45 pm »
George
+1
I would also think some headphone amp owners would have some interest as well.
Wayne1
« Reply #3 on: 15 Mar 2009, 04:22 pm »
Thank you George and Dave.
If you know of any headphone amps and/or owners that would like to try these adapters out,  please get in touch with me.
I would like to make these and other tube adapters available to any who could use them.
These particular adapters were built to sub a 6SN7 for a 6H30. The 9 pin base is the same as the 6DJ8, 6922, 7308 series of tubes.
If your filament winding can handle the current, swapping in octal bases will give you lots of options for tube rolling.
Another use I can see is using an EL34 in place of EL84 in amps. The amp would have to be re-biased to use the bigger tube, but it should not be too big a problem.
