0 Members and 1 Guest are viewing this topic. Read 2499 times.
I have a 15" driver feed almost a 1000 watts and like any good bass head like to crank it up a good bit for music and especially HT... Point being is this isnt fault due to poor quality bass.Thanks
For me Bass Traps helped a ton with fatigue. My room is close to a cube, so the same same frequencies were getting boosted in all directions, so I had a really strong resonant peak, that ended up sounding like a cheap 1 note boomy sub. The bass trapping will let you hear the quality sound you're sub is putting out, rather than room artifacts.Of course, your room may not be as bad as mine, but room treatments have been my best bang for the buck improvement - and greatly helped minimize fatigue.Jim C
Any small animals having "accidents" while you are watching a movie?"After about 30 minutes of tweaking the subs I went into the kitchen for a victory beverage and noticed that all three kittens had vomited all over their toys and cage floor."http://www.audiocircle.com/index.php?topic=61239.msg547819#msg547819
