chicago area rm2-neo repair?
0 Members and 1 Guest are viewing this topic. Read 1307 times.
JP78
« on: 14 Mar 2009, 01:08 am »
hello, a friend of mine recently damaged his rm2-neos while moving.  the movers snapped off the binding posts, and the left speaker intermittently comes in and out...sounds like something got loosened up in the crossover.
anyone know a reasonable and reputable shop i can point my buddy to have these small items repaired?
thanks guys,
John Casler
Re: chicago area rm2-neo repair?
« Reply #1 on: 16 Mar 2009, 06:49 am »
Any good DIY'er or repair shop should be able to repair or replace binding posts.
Soldering skills required.
However the older Solid Brass Posts are no longer available, so the replacement might need to be of a different manufacturer.
Will need to remove 12" woofer to access the inside portion of the binding posts.
