0 Members and 1 Guest are viewing this topic. Read 17149 times.
I'm thinking about building a house for stereo systems only, no other unnecessary rooms, well maybe a restroom. Lin
Hi guys,FWIW, I've got single Augies per channel in 45cm wide baffles, but also just built some ripole subs using two Eminence Beta-15A's per side, just because the drivers were selling cheap. I quite like the ripole, fairly similar to dipole Augies, but perhaps a bit more of the mid bass punch you guys are looking for, i.e dipole sound with a smattering of boxiness. Would be interesting to try dual ripoles using Augies - apparently it lowers fs by nearly 10hz so would be truly full range then. Also takes up less space (vertically anyway), and the cab is very still at high volumes due to push/pull vibration cancellation.
Linkwitz's dipole sub is also a ripole, the not with cones facing each other, as is a bit more common.
