0 Members and 1 Guest are viewing this topic. Read 17139 times.
Thanks dweekie....that makes me feel a bit better. I'm going to try slapping some MDF panels around the current setup to make an H frame, just to see what happens.I guess I wished it all worked exactly as wanted out of the box...no pun intended. But I suppose all this fooling around and testing is part of the fun.
What you guys think of using these servo drivers in a ripole setup, two drivers per channel, facing each other. I just built these using Eminence Beta 15A's and do like them, but am wondering what improvements servo control might bring.CheersB
I also find a bigger flat baffle to have less of that type of sound than a H and U frame arrangement. Good luck finding the best combination for your own use
Could somebody remind me who makes "Augies"? Thanks.
The baffle size I found that works the best (with the 15" Augies, anyway) have all been 22" X 22" with no extra reinforcement but the floor. No "H", no "U", no other letters of the alphabet. Just a plain 'ol baffle. A couple more drivers (if you've got the space) won't hurt a thing. Put them on the same baffle of course. The "double wide" baffle will also help as reinforcement.Bob
