Steve,
Yes, the sound has about the same intensity anywhere in the room now, unless one is very close to the speakers, not the usual listening position. I played an old mono vinyl to check for even sound.
I have experienced over the years the effects of hard reflective and soft damped surfaces particularly side and end walls have on reproduced music. But I have found that when the speakers are aligned using MS any influence on the sound appears to become more apparent. And when an anomaly is identified it can in most cases be dealt with by one means or another. ie:- covering a reflective surface or removing some covering etc. I have also found that by trying to balance the reflective properties (left and right sides of a room) will assist in make the MS process easier. After all the MS speaker alignment process is a balancing act in a room full of many variables.
I have found that the bass never really changes with the woofer off, the intensity just diminishes. But having said that, in my situation with all the stuff in the room the bass is absorbed and the woofer just makes more bass. However, a considering the laws of physics a 12" driver will push more air than a 8" driver. In my case the woofer is tuned as a bass extender to the VSonics to round out the bottom end sound. A worked over 400W @ 8 ohms woofer amps provides the variable grunt. So I suppose that I can overcome limited bass dynamics on some CD's as well as a dead room.
As a result of the MS process the speakers are as close to the wall as possible, nearly hard against a pair of built in 35 YO KEF transmissionlines which are nearly the size of a small fridge.
Laurie
