tonearm rewire
0 Members and 1 Guest are viewing this topic. Read 1688 times.
Derockster
tonearm rewire
« on: 12 Mar 2009, 12:57 am »
Hi,anyone know where I can get my SME series 111 tonearm rewired??Regards derockster
TheChairGuy
Re: tonearm rewire
« Reply #1 on: 12 Mar 2009, 01:36 am »
Derockster
Re: tonearm rewire
« Reply #2 on: 12 Mar 2009, 08:57 am »
Thank you.Cleaton
Derockster
Re: tonearm rewire
« Reply #3 on: 14 Mar 2009, 10:29 am »
No luck with either one John.Can anyone here do the rewire for me?If not where I can I buy the little clips that attach the cartridge to the head shell?We're so limited here in Barbados :(
Wayner
Re: tonearm rewire
« Reply #4 on: 14 Mar 2009, 11:04 am »
I have some. They are used but should work for you. Hope you can solder. Is that the reason you want your tonearm rewired, cause you have a broken clip?
Wayner
Derockster
Re: tonearm rewire
« Reply #5 on: 14 Mar 2009, 11:10 am »
Yes Wayner,I've broken a clip or two clumsily :lol:.Don't mind them being used one man's garbage is another man's treasure aa derockster
Wayner
Re: tonearm rewire
« Reply #6 on: 14 Mar 2009, 11:21 am »
PM me your address and I will send you out a set of 4.
Wayner
