Question for Frank???
0 Members and 1 Guest are viewing this topic. Read 1484 times.
EV-MAN
« on: 11 Mar 2009, 03:58 pm »
Frank, I emailed you about getting remote put in my Insight Pat-5 And you got right back to me and let me know that there is not enough room. What about this could you make a kit that would be seperate and plug in to the Pat-5 to have remote? I know I should have thought about this before I had the old Pat-5 done and went with a new Insight pre to get this feature but hindsight is 20 20. Thanks William
avahifi
    • http://www.avahifi.com
Re: Question for Frank???
« Reply #1 on: 11 Mar 2009, 05:29 pm »
To try and do what you want on a one-off basis would cost more than simply trading up to the Insight preamp model you want with the remote control option.
Frank
« Last Edit: 11 Mar 2009, 08:26 pm by avahifi »
turkey
« Reply #2 on: 12 Mar 2009, 01:55 pm »
I would suspect that an external remote volume control would not perform as well either.
You would be taking an output from the same place on the switching bus as the tape outputs connect to, then routing it to the back panel and out the back of the PAT-5 chassis, and then into an external box.
Then it would go into the volume pot, and finally back out of the external box and into the PAT-5 chassis and to the line board.
You would wind up giving up some of the functionality of the PAT-5 since you'd probably have to re-purpose some of the RCA jacks on the back panel. You would almost certainly increase the noise floor and possibly decrease the channel separation. In addition, you might get some rolloff in the treble region from the increased capacitance of the wire after the volume pot.
For the external box itself, you would need a power supply for the remote receiver and to drive the motor on the pot. I suppose you could take the power from the preamp chassis, at the expense of yet more back panel real estate and some connectors and cable. (This assumes the power supply in a stock Insight PAT-5 is up to the task. If not, you're probably back to an extra supply in the external box.)
Then you'd have to buy the external box. Metalwork isn't cheap.
Next you'd have to fill the hole on the front panel of the PAT-5. That's going to be more or less ugly. I guess you could have a custom front panel made up. That won't be cheap either.
Finally, you'd have a one-off preamp that would be hard to sell if you ever need to get rid of it.
Did I leave anything out? :)
