Help! I Need Speaker Rebuilder Advise
0 Members and 1 Guest are viewing this topic. Read 1883 times.
JakeJ
« on: 10 Mar 2009, 07:22 pm »
Hello All,
I have a friend who need the drivers rebuilt in his Nestorovic speakers. No markings on the drivers whatsoever.
The surrounds rotted and the voice coils have suffered rubbing, badly.
I am looking for recommendations of professional driver rebuilders that have the ability to repair these. Any help would be greatly appreciated.
I did do a search and came up empty but may have used the wrong search criteria.
TIA,
Jake
Bob in St. Louis
Re: Help! I Need Speaker Rebuilder Advise
« Reply #1 on: 10 Mar 2009, 07:32 pm »
Steve Deckert of Decware is the only driver repair fella I know of.
Bob
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #2 on: 10 Mar 2009, 07:56 pm »
You might want to contact Bud Purvine at O'netics -- he served his "apprenticeship" with Nestirovic.
dave
JakeJ
« Reply #3 on: 10 Mar 2009, 10:44 pm »
Hi Bob & Dave,
Thanks very much. I'll try Bud Purvine first as he may know the OEM that provided drivers for Nestorovic. If no luck on to Mr. Deckert.    :bowdown: :rock:
Again I thank you. The owner of the speakers will be tickled if I make this happen for him.  :thumb:
Jake
mdabb
« Reply #4 on: 10 Mar 2009, 10:48 pm »
Hello,
I live near this place called "The Speaker Shop" and they have been known to do specialty repair work on speakers old an new. May want to look into it.
http://www.thespeakershop.com/home/speakerrepair.html
Hope it helps !!!
Andrew
JakeJ
« Reply #5 on: 10 Mar 2009, 11:03 pm »
Thank you, Andrew. I'll keep them on the short list.
Best,
Jake
laserman
  • Ambiguous-Optimist
« Reply #6 on: 11 Mar 2009, 12:05 am »
You can contact Bill at Millersound Speaker Repair.  Bill is a straight shooter and will tell you if he can do it.
Bill LeGall
Contact:
[email protected]
1.215.412.7700
http://www.millersound.net/about.htm
Best of luck,
Lou
EDIT: modified link above
« Last Edit: 11 Mar 2009, 04:45 am by laserman »
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #7 on: 11 Mar 2009, 02:25 am »
Clicking the link and getting a g&^$%@! unpassable Flash entry is awfully annoying :(
dave
laserman
« Reply #8 on: 11 Mar 2009, 04:41 am »
dave
Dave,
I hadn't been to the site in several months, but I just experienced the same issue.  I tried this side door link and it seemed to work fine.  http://www.millersound.net/about.htm.
Here is a story about Bill http://www.6moons.com/audioreviews/roadtour13/roadtour13.html
Lou
