Help!
0 Members and 1 Guest are viewing this topic. Read 1686 times.
1ZIP
Help!
« on: 9 Mar 2009, 11:39 pm »
How do you replace the fuses on a 4B ST?  I just lost the left channel when replacing the RCAs with XLRs, both lights are still green but the a fuse is only easy fix I can think of.   I assume you have to take the top off and what is that little compartment next to the power receptacle?  The BP-26 seems to be okay a least I'm getting both channels out of the headphones.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Help!
« Reply #1 on: 9 Mar 2009, 11:45 pm »
Do you have both switches on the back set to Balanced?
james
1ZIP
Re: Help!
« Reply #2 on: 10 Mar 2009, 12:00 am »
On the 4B ST there is only one Bal/Unbal switch and the left channel is also gone when I switch back to RCA's and Unbal operation. The bridged/individual switch is on individual in both Bal & Unbal opereations.
Re: Help!
« Reply #3 on: 10 Mar 2009, 12:20 am »
Hi,
Sorry I was thinking the SST which has one switch per channel.
The compartment you mentioned may have 2 fuses but I am not certain - you will have to check with Mike Pickett in the morning.
james
1ZIP
Re: Help!
« Reply #4 on: 10 Mar 2009, 12:29 am »
Does Mike have an 800 number?
Re: Help!
« Reply #5 on: 10 Mar 2009, 12:37 am »
1-800-632-8217
james
1ZIP
Re: Help!
« Reply #6 on: 10 Mar 2009, 12:41 am »
Thank you much.
