VRS/1 sub - intermittent buzz
0 Members and 1 Guest are viewing this topic. Read 1836 times.
bric
« on: 9 Mar 2009, 10:26 pm »
Anyone know why my VRS/1 subwoofer is sending a loud, intermittent buzz about every 10 seconds?  I unhooked the connections to relocate the sub.  After reconnecting, it seems to be searcing for a signal but preamp indicates sub signal is active.  Thanks.
dcc1433
Re: VRS/1 sub - intermittent buzz
« Reply #1 on: 9 Mar 2009, 10:48 pm »
Could it be something as simple as a ground loop problem? if so just add a two-prong adapter to plug and plug into wall. Sounds like it might be something different but worth a shot. Worked for me on other subs. Good luck
es347
  • ..I've got my eye on you...which one you say?
« Reply #2 on: 9 Mar 2009, 11:40 pm »
In my HT I get that buzzing whenever I power off my preamp before powering off my subwoofer but it's constant.  You might try a different cable between your preamp and sub.  Good luck and try to not let it drive you nuts. :guns:
