Bunch of tubes (a bit of everything)
0 Members and 1 Guest are viewing this topic. Read 1084 times.
dwk
« on: 9 Mar 2009, 12:46 am »
These have been sitting in the closet for years, and it's time to go. I'm guessing a bit on pricing in some cases, so if something seems out of line make me an offer. I'm completely out of the tube world, so no trades for other tubes.
All the following are new in box
JAN 6SL7WGT (Philips)  - 4 pcs. There is what looks like a date code of A 11/85. $50/set (I think they are these: http://thetubestore.com/jan6s.html)
JAN 5751 (GE)  - 1 pr. I suspect this is a matched pair, but have no way to verify. SOLD
6SN7GTB - Sylvania - 1pr  Looks like the rightmost tube here https://www.tubeworld.com/6sn7syl1.jpg except the printing is yellow and on the tube, not the base. $30/pr
5881/6L6WGC Sovtek - quartet. I would have guessed that I would have gotten a matched quad, but there are green stickers on the end which I am guessing indicates a testing/grading number. 3 are marked '260' and one is '220'.  $30/set
6SN7GT Sovtek - 1 pr.  $15/pr
6922 Sovtek. 1 pr - SOLD
12AX7 - Sovtek 1 pr - $10
12AX7 - misc. These are in JJ ECC83 boxes, but are not the same and are marked as 12AX7's. 1 pr. $offer
Loose tubes, used but look good.
Some of these came from an eico st-70, and other are probably new units I got with intent of retubing the Eico. Project died due to bad iron. Open to offers, preferably as a single lot.
12DW7 Philips. These look like tubes I might have picked up intending to re-tube. Look new.
7247 "Eico by Mullard". obviously a pull from the ST-70. single tube
7247  GE. single tube
12AX7A GE.  2 tubes, but they look slightly different so I won't call them a pair. used
7591. Two Eico branded tubes, two Sylvania. No idea on hours on these guys.
12BH7 - RCA
12AU7A IEC/Mullard. Single tube SOLD
« Last Edit: 10 Mar 2009, 02:55 pm by dwk »
rivieraranch
Re: Bunch of tubes (a bit of everything)
« Reply #1 on: 9 Mar 2009, 11:24 am »
Personal message sent.
doctorcilantro
« Reply #2 on: 10 Mar 2009, 05:44 am »
Can you PM with details on the Mullard AU7
thanks
j
dwk
« Reply #3 on: 10 Mar 2009, 02:54 pm »
Slightly slow on the update.
the 5751's, 6922's and the Mullard AU7 have been spoken for.
