Newbie multimeter recommendation
0 Members and 1 Guest are viewing this topic. Read 1374 times.
skchow
« on: 9 Dec 2003, 05:22 pm »
Hey all those electronic gurus out there,
I'm looking to dive head on into the world of diy audio, and am trying to make a decision on which multimeter to buy.  The number of different types of multimeters out there is just stupifying.   So my questions are, what features do I REALLY need, and should I just get an el cheapo with a gazillion different functions, or should I buy one of the nicer but more expensive ones?  Any help I can get is appreciated.
Sunny
RussKon
« Reply #1 on: 10 Dec 2003, 04:21 am »
if you are new to the field of electronics...just get yourself a low cost digital multimeter....
you can find them for about $20...
it will do almost anything you need to do right now....
if you get furthur into the field you might want to upgrade in the future...but this will give you a good start....
