Vincent SP-997 150 wpc Monoblocks - SOLD!
0 Members and 1 Guest are viewing this topic. Read 1714 times.
kevb
« on: 8 Mar 2009, 04:57 pm »
A pair of Vincent SP-997 monoblocks for sale.  These little amps are excellent performers - small, powerful, and flexible with remote or automatic operation, rca and balanced inputs, plus are very easy to place because of their size. They look like mini-Levinsons. Audio Advisor sells them for $1600 USD/pair.
This pair has had light use with me, and only a couple of very minor marks. One binding post on one amp is bent inwards slightly (received it that way), but that does not affect the sound or operation - I'd give it a 6/10 A-Gon rating.  E-mail me for pics of the actual units for sale if you are serious.  Original packaging is included, and local pickup is welcome.
Technical details
* Frequency response: 20 Hz - 50 kHz 0.5 dB
* Nominal Output Power RMS/8 Ohm: 150W, 4 Ohm: 250W
* Total harmonic distortion: < 0.1 % (1 kHz, 1 Watt)
* Input sensitivity: 1,2V, Signal-Noise ratio: > 95 dB
* Input impedance: 47 kOhm, Inputs: 1 x RCA, 1 x XLR,
* Outputs: 2 x Speaker Terminal, 12 V Trigger input and switch-off-automatic
* Dimensions (WxHxD): 160 x 268 x 225 mm, Weight: 6.5 kg
Price excludes transport or transaction fees.....pics to follow.  SOLD!
« Last Edit: 7 Apr 2009, 11:46 pm by kevb »
kevb
Sold!
