0 Members and 1 Guest are viewing this topic. Read 4079 times.
The ATI multi-channels amps are a very good match with the Song Towers.I use an ATI 1506 to drive three Song Towers and I really like that combination.
Who makes the rest of their stuff? As an aside.
Thank you all for the comments and suggestions.I'm looking more at the Parasound A23. Also a used Citation 4-channel, and will check into AVA. But I think powering L,C,R from the same amp is the way to go. I've also seen good deals on the older Parasound HCA-1203A. So I'm leaning toward at least a 3-channel amp.
Quote from: oldmp3 on 9 Mar 2009, 09:38 pmThank you all for the comments and suggestions.I'm looking more at the Parasound A23. Also a used Citation 4-channel, and will check into AVA. But I think powering L,C,R from the same amp is the way to go. I've also seen good deals on the older Parasound HCA-1203A. So I'm leaning toward at least a 3-channel amp.I recently heard the A23 on my Emerald Physics CS2's and have to admit that I wasn't very impressed. The sound was muddled, wooly, and lacking in speed and clarity.The AVA and ATI amps will substantially outperform this particular Parasound amp IMHO. The ATI will be at roughly the same price point as the A23, while the AVA will be more expensive.George
Quote from: zybar on 9 Mar 2009, 09:53 pmQuote from: oldmp3 on 9 Mar 2009, 09:38 pmThank you all for the comments and suggestions.I'm looking more at the Parasound A23. Also a used Citation 4-channel, and will check into AVA. But I think powering L,C,R from the same amp is the way to go. I've also seen good deals on the older Parasound HCA-1203A. So I'm leaning toward at least a 3-channel amp.I recently heard the A23 on my Emerald Physics CS2's and have to admit that I wasn't very impressed. The sound was muddled, wooly, and lacking in speed and clarity.The AVA and ATI amps will substantially outperform this particular Parasound amp IMHO. The ATI will be at roughly the same price point as the A23, while the AVA will be more expensive.GeorgeDoes that mean the outlaw amps will be on par with the parasound or are the components of the ATI and outlaw roughly the same?
QuoteI recently heard the A23 on my Emerald Physics CS2's and have to admit that I wasn't very impressed. The sound was muddled, wooly, and lacking in speed and clarity.The AVA and ATI amps will substantially outperform this particular Parasound amp IMHO. The ATI will be at roughly the same price point as the A23, while the AVA will be more expensive.GeorgeGeorge, did you hear the Parasound A23 with the SongTowers? I have used the A23 with my SongTowers for several months and would not characterize it as sounding muddled, wooly and lacking in speed and clarity. This is also not a description that I have read in any of the several reviews on the A23 amp. I also have Parasound A21 and A51 amps and find the A23 to have a similar sonic signature when not driven to its limits. I accept your assessment that the Parasound A23 may not be a good match for the Emerald Physics CS2. I have read that some owners of the CS2 have suggested while efficient the match with amp is important. On the other hand the SongTowers are a fairly easy load to drive that seem to perform well with a variety of amps. It is a stretch in my opinion to conclude from your experience with the CS2 that the A23 would display similar shortcomings with a very different speaker, like the SongTowers.
Just the CS2's and I don't think we were driving it to anywhere close to its limits.What probably is a bigger factor is that I am used to hearing or using gear that performs at a much higher level than the A23 does.I don't know why it is hard to believe that in comparison to gear costing 2x or more that the A23 would sound the way I described it. While the SongTowers are definitely a more forgiving speaker than the CS2's, I don't believe the sonic characteristics I heard would be radically different if I tried the A23 at home with the SongTowers against the ATI or AVA amps I mentioned.Just curious, what is the rest of your associated gear? Have you compared your Parasound amps to other amps?BTW, in my limited listening to the A51 amp, I did not hear the negatives I heard with the A23 and I didn't think the A23 and A51 sounded very similar. Of course since I didn't perform any extensive comparison or try either amp at home, you can take my comments in that context.George
