FryCleaner Wire Burning?
0 Members and 1 Guest are viewing this topic. Read 2611 times.
ABEX
« on: 9 Dec 2003, 10:45 am »
I was wondering what the effect of burning a 1000' spool of 24ga. solid core wire would be?
Is there just to much resistance for it not to have adequate effect?
TIA
hagtech
« Reply #1 on: 10 Dec 2003, 05:11 am »
It should work.  A thousand feet should have less than 100 ohms resistance.  Just short the far end and drive one side with FryKleaner on high.  Can do four spools at a time this way.
jh :)
ABEX
« Reply #2 on: 10 Dec 2003, 08:40 am »
I set it up to run from Positve to negative the way you would with an IC's I think. I used a piece of wire with Allegator clips at both ends attached to Pos. & Neg. sides.
The Solid Core wire is single wire no pos\neg. legs to be concerned with.Therefore I just ran it straight.
Hope that made sense.L :lol:
