0 Members and 1 Guest are viewing this topic. Read 3795 times.
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1241553471&/dynaco-pas-3-van-alstine-moddeI don't believe it is, since you are against the Wonder Caps and all.....
Frank, is the shielding for the transformer useful at all, I don't supposed you suggested it? Also, did you design a solid state power supply for this, since the rectifier tube is missing?
Quote from: mark funk on 8 Mar 2009, 03:44 pmYa, I know, for $400 the caps should be a lot bigger
What are you guys talking about??? I have eight blue caps in my U70. Count 'em, two per phase per channel. Ron
Yah but the light blue ones sound a lot better than the dark blue ones.Regards,Frank
Well geeze, I do use four big blue caps on each Ultimate 70 rebuild. That must be the reason the sound so good.
Or - - - could it just possibly their electrical VALUE and how they are integrated into the circuit taking all the pole points needed into consideration.
I hope you didn't just go down to the hardware store and buy some latex paint. That will give it a "rubbery" sound. You need to score some NOS Sherwin-Williams oil based paint with the "cover the earth" logo embossed on the bottom of the paint can. It may be pricey, but you get what you pay for.
