Sedona Sky Speaker Cables
0 Members and 1 Guest are viewing this topic. Read 1343 times.
Sedona Sky Sound
« on: 9 Dec 2003, 04:40 am »
Sorry to plug my own, but I offer a bi-wire cable for $180 for a 3 meter pair. It is quad 12 AWG for the bass section and quad teflon covered 16AWG for the mid/highs. I typically terminate it with "o" spades for people that have speakers/amps in which the binding post nut can come off. It makes a better connection and ensures that the cable will never accidently come loose. If your binding post nut cannot be removed, then I just use the normal "u" spade.
Julian
www.sedonaskysound.com
Sedona Sky Sound
« Reply #1 on: 9 Dec 2003, 05:08 pm »
The above was originally posted in response to someone looking for speaker cables under $200 and suggestions on what to look for. I guess the moderator didn't think it was appropriate  :oops: . Since I am here, I might as well give the whole line:
ScorpionWire Bi-Wire Speaker Cable: $150 for 1 meter pair, $15 per additional meter
ScorpionWire Single Ended Analog Interconnect: $65/.5 meter, $75/1 meter, $85/1.5 meter pair This cable uses Teflon covered SPC wrapped around a natural fiber core. The whole cable is then wrapped in teflon tape before shrink tubing is applied. The terminations are locking, WBT style RCAs.
ScorpionWire Balanced Analog Interconnect: $75/.5 meter, $85/1 meter, $95/1.5 meter. Same basic design as above with gold XLRs.
I use high quality Cardis silver solder for all terminations. My interconnects are NOT shielded so I do not advise using lengths over 2 meters. My testing indicated that shielding increased the capacitance which had a detramental effect on sound quality.
Julian
[email protected]
512-332-2907
Mad DOg
« Reply #2 on: 9 Dec 2003, 05:18 pm »
Quote from: Sa-dono
The main factor we would like to avoid is direct recommendations of your own products.
this is why your post was moved...
