0 Members and 1 Guest are viewing this topic. Read 11362 times.
...the AV123 LS series, while it very impressive speaker, uses fairly low quality drivers compared to nearly anything Selah sells. They are the same Peerless India woofer is used in the $249 X-LS series. -Will
I have a 15wide by 22long by 10 high dedicated home theater room. 50/50 music movies.Is this room too small for line arrays or would I be better off with point source.Trying to decide between salk ht3 and av123 ls6 or selah or vmps 40
Thanks for the help guys. I think I like the idea of being able to fill the room with line arrays and will probably go that route. Do you know of any problems timbre matching the center and surrounds? I notice most of the line array companies seem to just sell left and right. Can I lay an array on the side for the center?tia
High quality I guess is a relative term, but I think seas and accuton woofers are on a quite different level from peerless ones. In a line array it's possible that the difference might be diminished but in conventional speakers it would be obvious, imo. I think many people would rank fountek ribbon over BG planars as well.
